How do I become a beta tester?
Get the beta version
You can download a beta version of the app via these channels:
GitHub releases
We publish all of our releases there. Beta versions are marked with a “Pre-release” label.
Play Store
You should be able to join the beta program using the Google Play Store app on the device. Look out for the “Join the beta” section in K-9 Mail’s detail page.
F-Droid
Unlike stable versions, beta versions on F-Droid are not marked with a “Suggested” label. You have to manually select such a version to install it. To get update notification for non-suggested versions you need to check ‘Settings > Expert mode > Unstable updates’ in the F-Droid app.
Report bugs
To report bugs found in the beta version use K-9 Mail’s issue tracker on GitHub. Please make sure the bug hasn’t been reported before by searching existing issues, also those that have already been closed.
Beta: K-9 Mail 5.718
GrapheneOS, k9 syncing disabled
Beta: K-9 Mail 5.716
Beta: K-9 Mail 5.717
Duplicate Trash Folders
How to upgrade from 5.600 to 5.7xx without losing mails?
Beta: K-9 Mail 5.732
Always says SYNC disabled
New beta: K-9 Mail 6.305
Beta: K-9 Mail 5.730
Beta: K-9 Mail 5.739
Mail in sent box not sending over internet
Beta: K-9 Mail 5.728
New beta: K-9 Mail 6.312
Beta: K-9 Mail 5.727
Cant save attachments to phone
Beta: K-9 Mail 5.740
Beta: K-9 Mail 5.904
Beta: K-9 Mail 5.903
Beta: K-9 Mail 5.720
Beta: K-9 Mail 5.901
Beta: K-9 Mail 5.721
Beta: K-9 Mail 5.906
K9 v5.6 cannot find the file explorer to select the download path
Sync of sent and deleted
Beta: K-9 Mail 5.908
Beta: K-9 Mail 5.722
Beta: K-9 Mail 5.724
Beta: K-9 Mail 5.913
Beta: K-9 Mail 5.910
Beta: K-9 Mail 5.723
How to never mark mails as seen?
Beta: K-9 Mail 5.912
Plans for K-9 Mail 6.000
Beta: K-9 Mail 5.731
K-9 Mail Outlook365 settings
Letters MA crash k9
Help wanted: Testing latest K-9 Mail beta
My K9 on android only fetch emails when I open it
New beta: K-9 Mail 6.311
Beta: K-9 Mail 5.726
Autodetect imap smtp settings
Emails going straight to "Draft" folder
Autocrypt - allways added to headers
Attempting to sync K9 for first time with imap server via protonmail bridge
No notification in Android 9
Header and footer bar flicker
Draft messages go poof
Beta: K-9 Mail 5.737
Email address added by Texpand not recognized
How to Empty trash!
Beta: K-9 Mail 5.738
New (beta) release: K-9 Mail 5.801
Not receiving update from googleplay
Beta: K-9 Mail 5.905
New beta: K-9 Mail 6.310
Beta: K-9 Mail 5.907
Beta: K-9 Mail 5.909
No Notification LED anymore
Beta: K-9 Mail 5.914
The plan for K-9 Mail 6.200
Beta: K-9 Mail 5.911
Sending Mail Stopped Working
Beta: K-9 Mail 5.915
Beta: K-9 Mail 5.916
Sort by sender doesn't work
New beta: K-9 Mail 6.301
New beta: K-9 Mail 6.302
New beta: K-9 Mail 6.303
New beta: K-9 Mail 6.308
New beta: K-9 Mail 6.307
New beta: K-9 Mail 6.309
Copies of sent mail
