Open/start screen for K9
There are a lot of us that want K9 to open to the list of email accounts.
This was the way that K9 could be opened up until the start of this decade.
When the previous developer changed this at the start of this decade, the 5 star app turned into a 2 or 1 star app.
If Thunderbird brings back the ability to open K9 to the list of email accounts, K9 will return to a 5 star app within days.
This doesn’t need to be the only way to open K9. Just add an option in Settings, just like being able to open at a Unified list or not.
If Thunderbird look at the K9 app reviews from around 2021, you will see when the 5 star rating crashed due to the new UI, which removed the ability to open at the list of email accounts.
If you use a 32 bit phone, look for Open Mail, which has the UI that had the 5 star rating, being able to open at a list of email accounts.
Over to you, Thunderbird.
Yep, still using K-9 Mail , version 5.600 due to complete ignorance of dev(s) to bring back things way it was.
This sounds like an interesting idea, I know users have different preferences when loading the app. On the other hand, we don’t want to overload the app with too many settings. I think there are enough different needs so that users won’t immediately bring the ratings back to 5 stars for this one feature though. The current average rating is higher than back before the 5.807 release :slight_smile:
For enhancement suggestions like this, would you mind posting them over on Mozilla Connect? This is a great place for the community to discuss and help shape ideas together, and is something we review regularly to determine the future roadmap.
To get the most out of your post, check out this quick guide on crafting impactful suggestions. Focusing on the problem your idea solves and how it could help others can really make it stand out!
Looking forward to seeing your idea there, this will help find out how well received a change like this would be.
The removal of this feature which is why so many dudes using K9 was the core (only) reason for the rating to crash. All of us using K9 at the time know about this.
As for K9 having a better star rating from 2021 is so easy. So many others came to K9 after the rating crash and didn’t know how good K9 was for multi account users. But K9 rating has never got back to where is was back in those days.
I have posted on Moz Connect but that isn’t the best place for K9 ideas. K9 stuff gets drowned out by all other Moz programs.
I am still using K9 hoping it will become a great app again eventually, but I am constantly being frustrated by the awkward interface for multiple email accounts.
Same with me.
I just started having some authentication errors and haven’t been able to check one of my accounts via K9 for a few days now. If it’s an OAuth2 issue, it seems like I’ll have to update K9, which is why I ended up back here. I wanted to see if the current version still has that same combined mailbox.
Sounds like it does, which means I’ll have to find a different program. I tried the unified inbox when it was forced on us, hated it, reloaded 5.6 and haven’t looked back.
I’d much rather stick with K9, but the unified inbox doesn’t work for me. I’m surprised it’s it’s still being used.
I guess that’s because it does work for a lot of users, but happy users tend not to post
I agree, but there was an awful lot of commotion when they introduced it and I know I’m not the only one still running an older version.
Let me update that from “the unified inbox doesn’t work for me. I’m surprised it’s it’s still being used.” to “the unified inbox doesn’t work for me. I’m surprised they haven’t added an option to disable it”.
For me, personally, having all my emails from multiple accounts on one screen doesn’t work for me. For how I use K9, a unified inbox is a dealbreaker. Right now it’s checking 4 accounts, two of them are gmail accounts. I’m only having this authentication error on one of them and it’s happened in the past as well. If it doesn’t clear up in another day or two, I’ll try the current version, but I’ll likely end up with something else.
There always has been an option to disable the unified inbox
Then I’m confused as to what was going on when I, and lot of other people, downgraded back to 5.6 because of the unified inbox and lack of account overview?
I suppose, before I get too concerned, I should ask if you think it’s possible this is a glitch with gmail that might clear itself up (I believe I’ve had this same problem in the past and after a few days it stopped happening) or something that will actually require updating the app?
I ask because two of my accounts are gmail accounts, but this is only happening with one of them. Not sure if it makes a difference, but the one that’s still working is a standard @gmail.com, the one that isn’t working is an @mydomain.com address that’s running though gmail.
The unified inbox was always there (and could always be disabled). It has nothing to do with the account overview screen. Note that the side bar now shows an account overview since a couple of months.
In the settings for the failing gmail account, walk through the Fetching | Incoming Server and Sending | Outgoing server settings.
Click Next on each, where it does a service check. It’s here you may need to re-authenticate for OAuth2.
I already moved over to another client. After all these years, K9 Mail no longer appears to work the way I need it to work.
I did update it to the current version, but not having the account overview front and center when I start the app, for me personally, is a deal breaker.
Replacing the account overview with the shade the slides in from the left. That doesn’t work for me. And if you miss the shade, it’ll select an email or open the link it thinks you were clicking on. That doesn’t work for me. Having each account identified by two letters instead of the account’s name. That doesn’t work for me.
Give me the v5.6 era version of the account overview and I’ll by happy, but without it, this email client just isn’t for me.
It’s not like I’m the only person that wants it back. I’m surprised the developers are willing to die on this hill.
Another problem with the current K9, it seems that it has been coded by bloody iphone users. Android has a back button but the only thing that is does in the current K9 is exit the app, no matter how far down you have drilled down in menus/screens. The back button should be able to be used to go back to the previous menu/screen until you get to the top menu. And if at the top menu, then that is when the back button should exit the app.
Back works as expected for me, it backs only on level. Samsung Galaxy S24FE.
While I don’t have a physical Back button my Back gesture works as expected and goes to the previous screen, both in Settings and when reading emails. Oneplus 9 Pro, A15 Matrixx rom.
I know you are frustrated at this, but I haven’t seen an iPhone app that exits when you press the back button, and I’d appreciate if we could stick to the facts.
If the app is exiting then it might be a crash. LoggingErrors · thunderbird/thunderbird-android Wiki · GitHub will help figure out which crash it is.
