Version 6.4 is no longer marking emails as read? when they are selected and marked as read?
Is it possible to rollback to the previous version?
TIA
TIA
Working fine for me, I just checked - maybe you changed some setting?
And you should be able to simply install one of the older github versions … but back up your settings just in case.
Thanks for the reply.
No, I do not muck around much with settings, just accept the updates.
I found older apk files, but they will not install?
Do I have to remove the current program first?
Just tried now and can see the text change. The brightness of font when read seems to be more than before?
Might be just because I was looking at the screen in the dark.?
Thanks anyway.
Have a Great Xmas and New Year.
My wife and I both have this problem with V6.400. If you simply view an email it works ok. However, if you click download full message or view pictures options then exit the email, it remains as unread in the inbox. Very annoying.
I get the same problem
Please test it with a Samsung Galaxy S10 and Android last update
