Today, I received a couple new emails. I had K9 fetch them, and it crashed. It has since crashed on every attempt to start it, including after a system reboot. (Debug trace follows at end of post)
I had this issue a while back, and I suspect a certain kind of email that causes a crash because of the way it is structured. Question is, can I let K9 forget the last few mails without being able to start it?
I have Android 8.0 on a Shiftphone 5me (February 2020 update) and K9 5.600 (suggested version on F-Droid)
Debug trace follows:
--------- beginning of main
06-12 22:00:35.984 6935 6962 I OpenGLRenderer: Initialized EGL, version 1.4
06-12 22:00:35.987 6935 6962 I ProgramBinary/Service: ProgramBinaryService client side disable debugging.
06-12 22:00:35.987 6935 6962 I ProgramBinary/Service: ProgramBinaryService client side disable binary content debugging.
06-12 22:00:36.070 6935 6935 W StaticLayout: maxLineHeight should not be -1. maxLines:1 lineCount:1
--------- beginning of crash
06-12 22:00:36.171 6935 6935 E AndroidRuntime: FATAL EXCEPTION: main
06-12 22:00:36.171 6935 6935 E AndroidRuntime: Process: com.fsck.k9, PID: 6935
06-12 22:00:36.171 6935 6935 E AndroidRuntime: java.lang.IndexOutOfBoundsException
06-12 22:00:36.171 6935 6935 E AndroidRuntime: at android.graphics.Paint.getRunAdvance(Paint.java:2632)
06-12 22:00:36.171 6935 6935 E AndroidRuntime: at android.text.TextLine.handleText(TextLine.java:824)
06-12 22:00:36.171 6935 6935 E AndroidRuntime: at android.text.TextLine.handleRun(TextLine.java:1056)
06-12 22:00:36.171 6935 6935 E AndroidRuntime: at android.text.TextLine.drawRun(TextLine.java:475)
06-12 22:00:36.171 6935 6935 E AndroidRuntime: at android.text.TextLine.draw(TextLine.java:252)
06-12 22:00:36.171 6935 6935 E AndroidRuntime: at android.text.Layout.drawText(Layout.java:545)
06-12 22:00:36.171 6935 6935 E AndroidRuntime: at android.text.Layout.draw(Layout.java:289)
06-12 22:00:36.171 6935 6935 E AndroidRuntime: at android.widget.TextView.onDraw(TextView.java:6972)
06-12 22:00:36.171 6935 6935 E AndroidRuntime: at android.view.View.draw(View.java:19380)
06-12 22:00:36.171 6935 6935 E AndroidRuntime: at android.view.View.updateDisplayListIfDirty(View.java:18287)
06-12 22:00:36.171 6935 6935 E AndroidRuntime: at android.view.View.draw(View.java:19092)
06-12 22:00:36.171 6935 6935 E AndroidRuntime: at android.view.ViewGroup.drawChild(ViewGroup.java:4340)
06-12 22:00:36.171 6935 6935 E AndroidRuntime: at android.view.ViewGroup.dispatchDraw(ViewGroup.java:4126)
06-12 22:00:36.171 6935 6935 E AndroidRuntime: at android.view.View.updateDisplayListIfDirty(View.java:18275)
06-12 22:00:36.171 6935 6935 E AndroidRuntime: at android.view.View.draw(View.java:19392)
06-12 22:00:36.171 6935 6935 E AndroidRuntime: at android.widget.ListView.drawChild(ListView.java:3625)
06-12 22:00:36.171 6935 6935 E AndroidRuntime: at android.widget.AbsListView.dispatchDraw(AbsListView.java:2789)
06-12 22:00:36.171 6935 6935 E AndroidRuntime: at android.widget.ListView.dispatchDraw(ListView.java:3620)
06-12 22:00:36.171 6935 6935 E AndroidRuntime: at android.widget.AbsListView.draw(AbsListView.java:4705)
06-12 22:00:36.171 6935 6935 E AndroidRuntime: at com.android.internal.widget.ActionBarOverlayLayout.draw(ActionBarOverlayLayout.java:505)
06-12 22:00:36.171 6935 6935 E AndroidRuntime: at com.android.internal.policy.DecorView.dispatchDraw(DecorView.java:821)
06-12 22:00:36.171 6935 6935 E AndroidRuntime: at com.android.internal.policy.DecorView.draw(DecorView.java:807)
06-12 22:00:36.171 6935 6935 E AndroidRuntime: at android.view.ThreadedRenderer.updateViewTreeDisplayList(ThreadedRenderer.java:643)
06-12 22:00:36.171 6935 6935 E AndroidRuntime: at android.view.ThreadedRenderer.updateRootDisplayList(ThreadedRenderer.java:649)
06-12 22:00:36.171 6935 6935 E AndroidRuntime: at android.view.ThreadedRenderer.draw(ThreadedRenderer.java:757)
06-12 22:00:36.171 6935 6935 E AndroidRuntime: at android.view.ViewRootImpl.draw(ViewRootImpl.java:3380)
06-12 22:00:36.171 6935 6935 E AndroidRuntime: at android.view.ViewRootImpl.performDraw(ViewRootImpl.java:3182)
06-12 22:00:36.171 6935 6935 E AndroidRuntime: at android.view.ViewRootImpl.performTraversals(ViewRootImpl.java:2703)
06-12 22:00:36.171 6935 6935 E AndroidRuntime: at android.view.ViewRootImpl.doTraversal(ViewRootImpl.java:1602)
06-12 22:00:36.171 6935 6935 E AndroidRuntime: at android.view.ViewRootImpl$TraversalRunnable.run(ViewRootImpl.java:7407)
06-12 22:00:36.171 6935 6935 E AndroidRuntime: at android.view.Choreographer$CallbackRecord.run(Choreographer.java:948)
06-12 22:00:36.171 6935 6935 E AndroidRuntime: at android.view.Choreographer.doCallbacks(Choreographer.java:750)
06-12 22:00:36.171 6935 6935 E AndroidRuntime: at android.view.Choreographer.doFrame(Choreographer.java:682)
06-12 22:00:36.171 6935 6935 E AndroidRuntime: at android.view.Choreographer$FrameDisplayEventReceiver.run(Choreographer.java:934)
06-12 22:00:36.171 6935 6935 E AndroidRuntime: at android.os.Handler.handleCallback(Handler.java:869)
06-12 22:00:36.171 6935 6935 E AndroidRuntime: at android.os.Handler.dispatchMessage(Handler.java:101)
06-12 22:00:36.171 6935 6935 E AndroidRuntime: at android.os.Looper.loop(Looper.java:206)
06-12 22:00:36.171 6935 6935 E AndroidRuntime: at android.app.ActivityThread.main(ActivityThread.java:6760)
06-12 22:00:36.171 6935 6935 E AndroidRuntime: at java.lang.reflect.Method.invoke(Native Method)
06-12 22:00:36.171 6935 6935 E AndroidRuntime: at com.android.internal.os.Zygote$MethodAndArgsCaller.run(Zygote.java:240)
06-12 22:00:36.171 6935 6935 E AndroidRuntime: at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:845)
