[REQUEST] Check for new emails every minute
Would it be possible to add a frequency of 1 (or 5) minute(s) to check for new emails?
I guess it could be performances/ressources-consuming but for some business mailbox, it’s really important to check it as often as possible.
Thank you a lot in advance,
BG
No it is not possible due to Android limitations. Min 15 minutes is enforced.
If you want instant notification, use IMAP and enable Push.
thank you for the answer
I just discovered this topic : Is 15 minutes really the new minimum check interval?
