I just updated my K-9 to the new Beta and also installed the Thunderbird Beta. Importing settings worked fine btw
But in both versions the settings for Push are missing, only Poll can be selected or edited.
How do I get those Push settings back?
Weāre in the process of removing the folder class system. Folders are not configured directly via āManage foldersā. There should be an āEnable Pushā switch.
I found it, thank you
Another question: What about the account pictures/avatars, will they come back too? Without them the accounts look so ⦠ugly, generic lol
Thunderbird Beta for Testers, but push also works. The problem at the moment is that only the incoming folders are set to push. Other folders should not be set to push.
I havenāt played around with this in earnest yet, so I donāt know if this is correct or not.
It looks like avatars cannot be displayed at this time.
I too would like it to be displayed.
