Print option in Menu
I cannot find a print option in the message menu. Even through “Share” it is not possible in an easy way to print out an email.
Any plans to the menu to come closer to the contents of Thunderbird’s menu?
Yes, I am using HP print service app which works fine with some other apps by sharing document, e.g PDF viewer. But if I share a mail from K9 I do not get HP print service app presented.
Exact. Attachments are not the problem. They can be easily printed with the corresponding app. I am looking for an easy way to print the mail itself.
I concur.
I’ve been using K9mail app for a long time. And my only gripe is not direct print option! When are you going to add print? Will the collaboration/merger with Thunderbird help bring this ‘fundamental feature’ to the K9app?
Not having a Print or Export option is a major, major shortcoming in K-9 Mail. I am using it on a Chromebook as an Android app with a POP3 account. That is one reason why I do not convert to IMAP, because I would have no way to preserve emails in the Sent folder. Otherwise K-9 Mail works very well for me.
