Move buttons to the bottom
Material design seems to allow both top and bottom app bars (I looked at https://matetial.io). But I have to admit that I am not an Android developer so I might have missed something
Yes I think you are right @stphn . It is even explicitly allowed as far as I can see: Material Design - bottom bars
So if it is not Material Design that is prohibiting bottom bars, then what else could it be …
So I finally decided to upgrade to the newer version (reduced my usage from 2 accounts to one account so lack of overview screen wasn’t a showstopper anymore) and it seems that it works just fine but… top buttons are driving me nuts. It was always so convenient to operate k9mail with one hand and all actions were easily available with single-hand mode (I have small hands and recently got new device which is even bigger… grrrr with the makers of the phones nowadays) and it’s impossible to operate k9mail conveniently now. I either have to move my hand or use second hand to do anything.
PLEAAASE add option to move the action bars to the bottom!
Hello - I hope this message finds you all well!
I’m new to K9 Mail, and I must say I’m impressed! I really like the unified inbox and the unified inbox widget. I just downloaded the beta version to get the ability to swipe messages from the inbox, and that really helped make the app more usable!
I’m commenting here to request that the buttons within messages be moved to the bottom as well. All my phones are too large to reach the top of the screen with one hand. Moving the delete and other buttons to the bottom of this screen would make K9 Mail nearly perfect!
Thanks for your consideration…
Has this issue been revolved yet? I don’t seem to be able to find an option in settings for moving the buttons down in the bottom. It is still on the end-user-wish-list!!!
This is something I’d like to see as well, there are a few more commonly used buttons that could do better at the bottom.
In order to better track interest, could someone create an idea on https://connect.mozilla.org/t5/ideas/idb-p/ideas/label-name/thunderbird%20android ? Then others can go ahead and upvote this.
