Enable vibration, disable sound
Hi, is it possible to set notification on account level like this:
  • no sound necessary
  • vibration should be ebabled
Email notification is not so important for me to get a sound notification. But I would like to get vibrations so I can react when I am near the phone.
I am using S7 and there it seems that vibration can only be set if sound is enabled, too.
Any one else with same need / issue?
Depends on your Android version. From what you described, I think that you will need a silence file. Just Google for it. Basically, it is an audio file without sound; about a second long. Set that to the account’s notification sound.
Yes - right! Android 8 on S7 even has a selector for a “silence” sound. I will give it a try!
I always searched with wrong assumptions. :joy:
This works - thanks a lot!
It was working for me in K9 5.6 and I thought the update changed it. But it was me :slightly_smiling_face:
Now I only need a solution for
https://forum-new.k9mail.app/t/notification-led-no-longer-works/2014/2?u=stphn
and then all notification issues should be gone for me. But this might be something which I have to wait for in K9 6.0…
