Copy text does not high light correctly
Firstly thanks to all who have created a great program.
When I used S24Ultra, with the latest software, firmware and copy and paste in TB. (Noting it used to have contrast colour in copy a few updates back)
The copy highlights in same background colours as the text bg, so its very difficult to see where you are copying.
There is no contrast, its always white on white. Albeit a tiny bit different.
Is there a way to change or update this ti a different contrast colour. ???
Hi Davina
It’s a known issue affecting only the light theme. There’s no fix at the moment.
  • The issue is discussed in the forum thread here.
  • An open github bug report can be found here.
