zpcol
February 13, 2021, 10:10am
#1
Can add the same Gmail account?
What do you mean with “the same”? If you are asking how to set up Gmail with K-9, have a look at one of the existing threads on this forum, for example
Greeting
I’m interested in how to make sure I can receive gmail and outlook on K9 on the new Huawei p40 because I get an “authentication failed”
Thank you in advance
or
I’m trying to add a Gmail account to K-9 (currently using whatever latest beta is, on Android 11).
This is a new Gmail account and I thought I would try IMAP (all my other accounts in K-9 are POP3). Enabled in gmail settings on computer.
When I add the account to K-9, for Incoming Server Settings, it’s auto populated the right info according to gmail (server=imap.gmail.com , Security=SSL/TLS, Port=993, Username=[my email address], Authentication=Normal password, Password=[correct password], Aut…
