Widget settings on android 10
Hello
Is there a way to change widget’s settings once it has been placed on virtual screen?
Deleting existing one, and adding new widget doesn’t offer any way of configuration.
I haven’t found any information about this, nor on this forums, nor in github’s issues. K9’s documentation only mentions that K9 widgets do exist.
The “K-9 Message List” widget is not configurable and always shows the Unified Inbox. The other ones allow you to select an account and/or folder when adding them to the home screen.
@cketti Is there a plan for a dark (black) widget version?
Not in the foreseeable future. I’m happy to look at code contributions for this, though.
