"useless" notification problem
Hey,
since a few weeks now, i have a notification with text “Neue E-Mails abfragen”, which is “spinning” when the mails are synced.
I cannot kill the notification and its annoying me.
how can i turn of the notifcation?
Version 5.739
Redmi Note 10 pro
MUI 12.0.16
Android 11
Long-press it.
@cketti Should the notification maybe have a text explaining why it is needed? I assume this same question will get asked a lot now.
i dont want to turn off all notifications. Just this “empty” one.
See How to configure Push?
:+1:
I created an issue for it. Please comment if you have other/more ideas.
ah yeah, thanks for the fast help.
Just as a small data point on how we could make this easier to understand for future users: @getNo, did you touch the notification before asking or did you only read the text it showed?
i already tried to modify the notifications with a long press and already deactivated “miscellaneous” but with the inspiration of “how to configure Push” i found the Push notification to deactivated.
Like you two said before, a better hint in the notification should make it clear for the users.
After all, thanks for the fast help and your work on this app.
That is not really how notifications are supposed to work. Notifications get very cluttered if every program running shows some useless notification like that.
I configured the settings and it still shows “Waiting for new messages”. I can make it small by long pressing the notification. But disabling Push notifications seems to be only way to get rid of that useless message.
That’s a requirement by Google. Google wants notifications to work like this. Whenever an app does something persistent in a background service¹, it needs to show a notification. Push mail needs such a persistent background service. On modern Android versions you can hide the notification without affecting other notifications of K-9. To learn how to hide it, tap the notification.
¹ The technical term is actually foreground service but that could sound confusing to non-developers.
Google making rules for others, and not following those rules themselves? Gmail doesn’t do that. None of the other programs do that (yet, as far as I have seen).
Tapping that notification made it seem like it would disable Push notifications entirely for K-9.
That works because they own servers that can stay active and just “ping” the device when a message appears. K-9 needs to constantly check the emails itself.
You can choose to either disable push or to disable the notification.
