This is with my own server. If I use thunderbird, and tell thunderbird to place sent mail in the sent folder, it works. With K9, I can send mail, the recipient receives it, but it does not go in the sent mail folder. I have Upload sent messages checked in my settings.
Is there anywhere I can check for a log to see why this is failing or what is happening when it tries to place a message in sent?
Thanks!
edit: I am shamefully dumb. I went to the folders menu and saw that the folder was set to āautomatic: noneā by default. I thought it would use the sent folder by default. It didnāt occur to me that this could default to automatic, which would then give up and use ānoneā instead of the pre-existing āsentā folder. Either way, problem fixed incase anyone else is as dumb as me and misses this.
As far as I know K9 requests the folder mappings from server - if the mapping is not available it sets it to NONE. There are some other threads on forum about this and also a proposal to show a warning in case none is chosen.
Maybe you can check your server settings if there all is correct?
Also, please mark your message as āSolutionā to show others that this is solved. Thanks.
Can you elaborate on what you mean by ārequests the folder mappings from serverā.
Iāve recently discovered that my sent items havenāt been copied to my sent folder (which they used to do). I finally found the option under the Account settings page for each account I have setup.
In there, it said that it was set to āAutomatic (none)ā.
Iāve never heard of IMAP folder mapping, and I canāt see anything in the IMAP RFC about it. Is this an extension to the protocol, or something Iāve missed?
