Unified inbox not syncing. Gemeinsamer Posteingang synchronisiert nicht
This issue seems to perist for years. Yet no solution to be found here.
Individual inboxes work fine, unified one is ~1week behind.
Dieses Problem scheint schon seit Jahren zu bestehen. Dennoch ist hier keine Lösung zu finden.
Einzelne Posteingänge funktionieren einwandfrei, ein gemeinsamer ist ~1 Woche im Rückstand.
Please help
Without details, and better yet a log, I doubt you’ll get much help.
K-9 version, device, Android version, email provider, whether POP3 or IMAP are needed. Also check your settings to see which Inboxes are set to go to the Unified one.
I use K-9 on 4 OnePlus devices (all with IMAP of course), stock OOS + custom roms, A/OOS11 to A14, and on all of them the Unified Inbox syncs as it should. So I’m almost certain it’s not a K-9 but a setting issue. :woman_shrugging:
