Hi
I can’t configure the app cause appears the warning “unable to connect to server”
I’ll be grateful if someone will help me
Txs
Eriza
You need to provide more information for anyone to be able to help you. The needed bits include:
your mail provider’s documented settings
- server hostname(s) - these could be different for receiving and sending
- associated protocols and ports
the settings you are using
At the moment there are no dns records for the hostname “imap.distruzione.org”.
You will need to speak with the site’s mail system administrators to get the correct host information for imap access.
[screen shots weren’t really necessary here – providing the reqested information in text would have made it easier to use.]
I’ve solved the problem
thanks you so much
E.
