Suggestion : An "Undo" feature for swipe actions
Hello, I like the new swipe actions to the message list screen, it is very easy to delete a message for example.
…but, maybe, it’s too easy :
Sometime, I delete message because my phone choose “swipe” instead of “Android back button” when I make a drag from screen corner. (I use my phone without 3 classic Android bottom button, so only gesture)
After that, it is difficult to locate in the trash folder which email has just been deleted !
Please make an “Undo” popup for few second in screen bottom after a swipe action.
Thanks :slight_smile:
That would be very helpful!
Yes, I agree. A discrete popup at the bottom would be helpful to undo inadvertent swipe deletion.
It would also be possible to activate the setting to always show a confirmation for deleting messages, but this setting is quite annoying as it will actively ask for confirmation in all cases and it is not needed in most of the cases.
In addition, I propose to make the swipe gesture less “easy”, i.e., longer swipe distance to lower risk of inadvertently deleting messages.
Yes, a longer swipe distance is a good idea in association with discrete popup :slight_smile:
+1 for both suggestions. Deleting a mail is just too easy…
Still no “undo” feature !
Have the developers ever experimented with gesture navigation ?
Yes, we need an UNDO button!!
Don’t believe this. Why configure delete in the first place? Get a grip.
To delete very fast, of course !
I am SO in on this!
I used a different mail client for many years that had this feature and used it enough that I miss it.
Strongly agreed. In fact, k9 needs a very long stack of undos. I just accidentally lost a lengthy 2 hour composition to a family member. I have no idea how it got deleted.
This happens so often, i usually remember to draft the message in a different app, then paste it into k9 immediately before sending.
I’m on the verge of abandoning k9 due to this horrible accidental delete “feature”.
Either change this accidental delete function, or create a long undo stack.
I’ll second that (33rd?). I’ve been bitten by this a few times, and ended up turning on confirmation – but the problem with a confirmation popup is that 99% of the time you want to confirm it, and that trains you to just hit OK automatically…whereas a non-blocking short-lived Undo button stays out of your way for that 99% of the time you don’t want it and is there when you do.
I also be in favor of this. I would also mention I think a undo pop-up would be great for any file/delete action, even archive. Other applications, as well as their web counterparts, like Gmail and Outlook, have this functionality.
Any chance this might ever happen? I’ve accidentally deleted dozens of messages with a swipe (use that to go back in all other areas of my phone and ask it takes us a misplaced swipe and OH NO, WHAT DID I JUST DELETE?) and it just happened again. At least the ability to sort the deleted items by the last modified timestamp would be helpful so I could find what was just deleted a moment ago. As it is, all I know is it was something between the end of January and mid February that I wanted to keep but I have no idea what. So frustrating!
I just found out that other platforms use the swipe function also BUT let you confirm your choice in the now visible trash can. So the message swipes to the side, stays there and reveals the trash bin to be tapped on.
That would be very nice. Thank you Thunderbird Team!
I’d love to see this added too. It’s so easy to accidentally swipe the wrong way when you’re clearing through a full inbox, especially on a smaller screen. Having a brief ‘Undo’ snackbar pop up at the bottom would definitely save me from digging through the Trash folder to find whatever I just accidentally archived or deleted.
Mozilla connect is the best place to record your interest in the feature. You can vote for the idea here.
