I am having an issue with some emails vanishing from the inbox on K9 after they have been read. I can literally see the email vanish from the inbox after viewing the email and going back to the inbox. The emails (and it is only some, not all of them) are not moved to junk/deleted and if I view the inbox using a different email client (eg outlook or thunderbird on a pc) the missing emails are still in the inbox. They just do not show up in the inbox in K9.
It is not a server issue since the missing emails are visible in other email clients. It is as if K9 is tagging them as junk but rather than moving them to the junk folder, K9 is just making them invisible (but only to K9).
Has anyone struck this before and can anyone suggest a way of stopping it from happening?
For the record, this is on my wife’s phone. K9 does not do this on mine, even though it has the same setup and is using the same ISP (but a different account).
The latest versions of android & K9. It’s using the unified inbox, but the person in question only has one account. The issue also appears in the account’s inbox in K9.
I was also unable to replicate it on my android phone.
It could be the same issue you mentioned from 2024. I’ll add a me2 to that, although since K9 is being absorbed into thunderbird and it does appear to be a very rare issue, I doubt there will be any action on it. At least I know I’m not imagining things. The use has gone back to using outlook for android) which does not ‘eat’ the emails in question. I tried outlook (android), t’bird (windows) and even webmail and the missing emails all show up, it’s just K9 that’s hiding them. And I couldn’t see any setting that would have a bearing on it. I’ve posted to the t’bird reddit forum and no-one there has a clue either.
