Silent failure on Gmail sync
Hello
Last couple of days, K9 is no longer syncing my Gmail account. I use manual sync.
I have tried the following:
  • deleting and re-adding account (it works once after doing this)
  • checking incoming mail details (it works once after doing this)
  • trying a different app (Gmail works)
  • switching from WiFi to 4G and vice versa
On exporting debug logs, I see below error.
I have been using K9 for years now without any problems. Weird thing is I am not notified of the problem, it was only after checking with Gmail app I realized something was wrong
07-02 16:02:38.190 21830 21857 V RealImapConnection:
07-02 16:02:38.190 21830 21857 V RealImapConnection: ]]
07-02 16:02:38.191 21830 21857 V RealImapConnection: conn30709357<<<#8# [OK, Success]
07-02 16:02:38.191 21830 21857 D ImapSync: SYNC: Synced unsynced messages for folder INBOX
07-02 16:02:38.191 21830 21857 D ImapSync: SYNC: Have 0 large messages and 1 small messages out of 1 unsynced messages
07-02 16:02:38.191 21830 21857 D ImapSync: SYNC: Fetching 1 small messages for folder INBOX
07-02 16:02:38.192 21830 21857 V RealImapConnection: conn30709357>>> 9 UID FETCH 34322 (UID BODY.PEEK[])
07-02 16:02:41.854 21830 21857 E RealImapFolder: IOException for b9a60008-ea87-4995-964a-65313b253abc:INBOX/MessagingController/conn30709357
07-02 16:02:41.854 21830 21857 E RealImapFolder: java.net.SocketException: Software caused connection abort
07-02 16:02:41.854 21830 21857 E RealImapFolder: 	at java.net.SocketInputStream.socketRead0(Native Method)
07-02 16:02:41.854 21830 21857 E RealImapFolder: 	at java.net.SocketInputStream.socketRead(SocketInputStream.java:118)
07-02 16:02:41.854 21830 21857 E RealImapFolder: 	at java.net.SocketInputStream.read(SocketInputStream.java:173)
07-02 16:02:41.854 21830 21857 E RealImapFolder: 	at java.net.SocketInputStream.read(SocketInputStream.java:143)
07-02 16:02:41.854 21830 21857 E RealImapFolder: 	at com.android.org.conscrypt.ConscryptEngineSocket$SSLInputStream.readFromSocket(ConscryptEngineSocket.java:989)
07-02 16:02:41.854 21830 21857 E RealImapFolder: 	at com.android.org.conscrypt.ConscryptEngineSocket$SSLInputStream.processDataFromSocket(ConscryptEngineSocket.java:953)
07-02 16:02:41.854 21830 21857 E RealImapFolder: 	at com.android.org.conscrypt.ConscryptEngineSocket$SSLInputStream.readUntilDataAvailable(ConscryptEngineSocket.java:868)
07-02 16:02:41.854 21830 21857 E RealImapFolder: 	at com.android.org.conscrypt.ConscryptEngineSocket$SSLInputStream.read(ConscryptEngineSocket.java:841)
07-02 16:02:41.854 21830 21857 E RealImapFolder: 	at java.util.zip.InflaterInputStream.fill(InflaterInputStream.java:303)
07-02 16:02:41.854 21830 21857 E RealImapFolder: 	at java.util.zip.InflaterInputStream.read(InflaterInputStream.java:210)
07-02 16:02:41.854 21830 21857 E RealImapFolder: 	at java.io.BufferedInputStream.fill(BufferedInputStream.java:239)
07-02 16:02:41.854 21830 21857 E RealImapFolder: 	at java.io.BufferedInputStream.read(BufferedInputStream.java:258)
07-02 16:02:41.854 21830 21857 E RealImapFolder: 	at com.fsck.k9.mail.filter.PeekableInputStream.peek(PeekableInputStream.kt:31)
07-02 16:02:41.854 21830 21857 E RealImapFolder: 	at com.fsck.k9.mail.store.imap.ImapResponseParser.readResponse(ImapResponseParser.java:37)
07-02 16:02:41.854 21830 21857 E RealImapFolder: 	at com.fsck.k9.mail.store.imap.RealImapConnection.readResponse(RealImapConnection.kt:836)
07-02 16:02:41.854 21830 21857 E RealImapFolder: 	at com.fsck.k9.mail.store.imap.RealImapFolder.fetch(RealImapFolder.kt:609)
07-02 16:02:41.854 21830 21857 E RealImapFolder: 	at com.fsck.k9.backend.imap.ImapSync.downloadSmallMessages(ImapSync.kt:518)
07-02 16:02:41.854 21830 21857 E RealImapFolder: 	at com.fsck.k9.backend.imap.ImapSync.downloadMessages(ImapSync.kt:361)
07-02 16:02:41.854 21830 21857 E RealImapFolder: 	at com.fsck.k9.backend.imap.ImapSync.synchronizeMailboxSynchronous(ImapSync.kt:203)
07-02 16:02:41.854 21830 21857 E RealImapFolder: 	at com.fsck.k9.backend.imap.ImapSync.sync(ImapSync.kt:34)
07-02 16:02:41.854 21830 21857 E RealImapFolder: 	at com.fsck.k9.backend.imap.ImapBackend.sync(ImapBackend.kt:56)
07-02 16:02:41.854 21830 21857 E RealImapFolder: 	at com.fsck.k9.controller.MessagingController.syncFolder(MessagingController.java:644)
07-02 16:02:41.854 21830 21857 E RealImapFolder: 	at com.fsck.k9.controller.MessagingController.synchronizeMailboxSynchronous(MessagingController.java:584)
07-02 16:02:41.854 21830 21857 E RealImapFolder: 	at com.fsck.k9.controller.MessagingController.synchronizeFolderInBackground(MessagingController.java:2421)
07-02 16:02:41.854 21830 21857 E RealImapFolder: 	at com.fsck.k9.controller.MessagingController.lambda$synchronizeFolder$29(MessagingController.java:2393)
07-02 16:02:41.854 21830 21857 E RealImapFolder: 	at com.fsck.k9.controller.MessagingController.$r8$lambda$Sh5trCC-_siPBccOxT_UO3ffdJU(MessagingController.java:0)
07-02 16:02:41.854 21830 21857 E RealImapFolder: 	at com.fsck.k9.controller.MessagingController$$ExternalSyntheticLambda31.run(R8$$SyntheticClass:0)
07-02 16:02:41.854 21830 21857 E RealImapFolder: 	at com.fsck.k9.controller.MessagingController.runInBackground(MessagingController.java:227)
07-02 16:02:41.854 21830 21857 E RealImapFolder: 	at com.fsck.k9.controller.MessagingController.-$$Nest$mrunInBackground(MessagingController.java:0)
07-02 16:02:41.854 21830 21857 E RealImapFolder: 	at com.fsck.k9.controller.MessagingController$1.run(MessagingController.java:167)
07-02 16:02:41.854 21830 21857 E RealImapFolder: 	at java.lang.Thread.run(Thread.java:1012)
07-02 16:02:41.856 21830 21857 E ImapSync: synchronizeMailbox
07-02 16:02:41.856 21830 21857 E ImapSync: com.fsck.k9.mail.MessagingException: IO Error
07-02 16:02:41.856 21830 21857 E ImapSync: 	at com.fsck.k9.mail.store.imap.RealImapFolder.ioExceptionHandler(RealImapFolder.kt:1201)
07-02 16:02:41.856 21830 21857 E ImapSync: 	at com.fsck.k9.mail.store.imap.RealImapFolder.fetch(RealImapFolder.kt:649)
07-02 16:02:41.856 21830 21857 E ImapSync: 	at com.fsck.k9.backend.imap.ImapSync.downloadSmallMessages(ImapSync.kt:518)
07-02 16:02:41.856 21830 21857 E ImapSync: 	at com.fsck.k9.backend.imap.ImapSync.downloadMessages(ImapSync.kt:361)
07-02 16:02:41.856 21830 21857 E ImapSync: 	at com.fsck.k9.backend.imap.ImapSync.synchronizeMailboxSynchronous(ImapSync.kt:203)
07-02 16:02:41.856 21830 21857 E ImapSync: 	at com.fsck.k9.backend.imap.ImapSync.sync(ImapSync.kt:34)
07-02 16:02:41.856 21830 21857 E ImapSync: 	at com.fsck.k9.backend.imap.ImapBackend.sync(ImapBackend.kt:56)
07-02 16:02:41.856 21830 21857 E ImapSync: 	at com.fsck.k9.controller.MessagingController.syncFolder(MessagingController.java:644)
07-02 16:02:41.856 21830 21857 E ImapSync: 	at com.fsck.k9.controller.MessagingController.synchronizeMailboxSynchronous(MessagingController.java:584)
07-02 16:02:41.856 21830 21857 E ImapSync: 	at com.fsck.k9.controller.MessagingController.synchronizeFolderInBackground(MessagingController.java:2421)
07-02 16:02:41.856 21830 21857 E ImapSync: 	at com.fsck.k9.controller.MessagingController.lambda$synchronizeFolder$29(MessagingController.java:2393)
07-02 16:02:41.856 21830 21857 E ImapSync: 	at com.fsck.k9.controller.MessagingController.$r8$lambda$Sh5trCC-_siPBccOxT_UO3ffdJU(MessagingController.java:0)
07-02 16:02:41.856 21830 21857 E ImapSync: 	at com.fsck.k9.controller.MessagingController$$ExternalSyntheticLambda31.run(R8$$SyntheticClass:0)
07-02 16:02:41.856 21830 21857 E ImapSync: 	at com.fsck.k9.controller.MessagingController.runInBackground(MessagingController.java:227)
07-02 16:02:41.856 21830 21857 E ImapSync: 	at com.fsck.k9.controller.MessagingController.-$$Nest$mrunInBackground(MessagingController.java:0)
07-02 16:02:41.856 21830 21857 E ImapSync: 	at com.fsck.k9.controller.MessagingController$1.run(MessagingController.java:167)
07-02 16:02:41.856 21830 21857 E ImapSync: 	at java.lang.Thread.run(Thread.java:1012)
07-02 16:02:41.856 21830 21857 E ImapSync: Caused by: java.net.SocketException: Software caused connection abort
07-02 16:02:41.856 21830 21857 E ImapSync: 	at java.net.SocketInputStream.socketRead0(Native Method)
07-02 16:02:41.856 21830 21857 E ImapSync: 	at java.net.SocketInputStream.socketRead(SocketInputStream.java:118)
07-02 16:02:41.856 21830 21857 E ImapSync: 	at java.net.SocketInputStream.read(SocketInputStream.java:173)
07-02 16:02:41.856 21830 21857 E ImapSync: 	at java.net.SocketInputStream.read(SocketInputStream.java:143)
07-02 16:02:41.856 21830 21857 E ImapSync: 	at com.android.org.conscrypt.ConscryptEngineSocket$SSLInputStream.readFromSocket(ConscryptEngineSocket.java:989)
07-02 16:02:41.856 21830 21857 E ImapSync: 	at com.android.org.conscrypt.ConscryptEngineSocket$SSLInputStream.processDataFromSocket(ConscryptEngineSocket.java:953)
07-02 16:02:41.856 21830 21857 E ImapSync: 	at com.android.org.conscrypt.ConscryptEngineSocket$SSLInputStream.readUntilDataAvailable(ConscryptEngineSocket.java:868)
07-02 16:02:41.856 21830 21857 E ImapSync: 	at com.android.org.conscrypt.ConscryptEngineSocket$SSLInputStream.read(ConscryptEngineSocket.java:841)
07-02 16:02:41.856 21830 21857 E ImapSync: 	at java.util.zip.InflaterInputStream.fill(InflaterInputStream.java:303)
07-02 16:02:41.856 21830 21857 E ImapSync: 	at java.util.zip.InflaterInputStream.read(InflaterInputStream.java:210)
07-02 16:02:41.856 21830 21857 E ImapSync: 	at java.io.BufferedInputStream.fill(BufferedInputStream.java:239)
07-02 16:02:41.856 21830 21857 E ImapSync: 	at java.io.BufferedInputStream.read(BufferedInputStream.java:258)
07-02 16:02:41.856 21830 21857 E ImapSync: 	at com.fsck.k9.mail.filter.PeekableInputStream.peek(PeekableInputStream.kt:31)
07-02 16:02:41.856 21830 21857 E ImapSync: 	at com.fsck.k9.mail.store.imap.ImapResponseParser.readResponse(ImapResponseParser.java:37)
07-02 16:02:41.856 21830 21857 E ImapSync: 	at com.fsck.k9.mail.store.imap.RealImapConnection.readResponse(RealImapConnection.kt:836)
07-02 16:02:41.856 21830 21857 E ImapSync: 	at com.fsck.k9.mail.store.imap.RealImapFolder.fetch(RealImapFolder.kt:609)
07-02 16:02:41.856 21830 21857 E ImapSync: 	... 15 more
07-02 16:02:41.860 21830 21857 E ImapSync: Failed
This topic was automatically closed 180 days after the last reply. New replies are no longer allowed.
