Sent mails invisible
Why are sent emails not shown in the ‘sent’ map? (nor anywhere else)
They are showing just fine here. Check the account folder settings, they probably have a wrong/invalid Sent folder specified.
YES! Thanks, found and corrected.
BUT very funny, this default setup (I didn’t change anything after installing the app). :thinking:
Probably due to the language difference? Judging by your nick your (system) language is probably German, so maybe that confused the app lol.
If my post was the solution then please use the checkbox under it to mark it as “solved” :wink:
