Using K9 for Android, suddenly all my messages in the sent folder show the sender only (me). I cannot see who each was sent to without opening each. Which setting controls this, please?
Check in Settings / account / Folders / Sent folder
If it is None then I can reproduce the behavior. If it is set to specific folder it works fine for me.
Also if None is set then sent mails will not be saved in any folder as far as I know
Thank you. This fixed it. The settings had been correct but something changed each assigned folder to “Automatic (none)”. Good job by responder.
