My sent emails do not appear in sent folder? The box is ticked to upload to folder and Im using imap
Go to “Settings / (account) / Folders / Sent folder”. You suspect it is not what you expect there. Maybe even “Automatic (None)”, which causes your sent mails to not be stored anywhere… (I consider that a bug.)
Please choose a suitable folder. I recommend a folder on the server. (You are using IMAP, I assume. If not, I HIGHLY recommend you switch to IMAP.)
I am using imap and you were right, automatic none. Ive corrected and all working.
Thanks.
