Sent folder not found
very annoying. how do i get rid of this?
As the message suggests, you don’t have a sent folder assigned.
  1. Navigate to settings > account > folders
  2. Assign a folder name to the “Sent folder”
I presume clicking the “Assign Send Folder” button in your screen shot will take you to the same settings page. See here more information.
I am aware. I do not use a sent folder on purpose. That notice never bothered me up until last update.
Jack Movsesyan
Could you check if the setting below is enabled and try disabling it.
  • Settings > account > sending mail:
    Upload sent messages (upload messages to sent folder after sending)
it is disabled, popup still shows upon sending
Jack Movsesyan
What version of the app are you using?
The feature looks to have been scheduled for v15, though not mentioned in the release notes.
I’d recommend raising a bug report on github. A better approach would be where the app takes the status of setting “Upload sent messages” into account, and only displays the confirmation dialog when it’s enabled and a sent folder is unassigned.
I have the same problem. (K9 15.0)
On one account I use, I have removed the sent folder and also disabled “Upload Sent Messages”.
I always get this Warning since the last update.
It’s curious, because #9912 explicitly mentions issue #6276 where the proposal actuall was:
If “Upload sent messages” is checked but ”Sent folder“ is “Automatic (None)” show a warning message when the user tries to send an email.
So the initial feature definition already included the conditional.
Same problem. Sent folder is explicitly set to “none” - changed from automatic.
As previously suggested, create an issue ticket on github and see what feedback the developers provide. It might be that they overlooked the sent message setting, or have a reason for not taking it into account.
It sounds like you’re dealing with a classic IMAP folder mapping headache. Have you checked if the “Sent” folder is set to “Push” or “Poll” in the folder settings? Sometimes K-9 won’t display it in the main list until the folder classes are refreshed or specifically marked as “1st Class.”
