Thanks for reading.
I am struggling to understand why I cannot seem to get an inline image to appear in GMail.
Having inserted a Base64 stream of an image, I am able to send that to Hotmail and alike, however whatever else I try it will not be seen in Gmail.
All I see is CAT_IMAGE with the typical missing graphic icon before it.
Debugging code at both ends, in K9 and in Gmail these are my results.
I would greatly appreciate any suggestions / guidance, etc, on this.
Cheers
a) In K9
The message seems to me sending as a Mime message fine.
MIME Header
Date: Thu, 04 Apr 2024 14:04:48 +1000
To: My Name <myemail@gmail.com>
Subject: Test Image 18
X-Priority: 3
User-Agent: K9 for Android
Message-ID: <D8482783-50D6-4F86-85C3-405B19E0EE84@gmail.com>
----XIKD9N7GIEH1CN8UWAJQ38SFJDKT7A
Other information that may be helpful is as follows ;
composedMimeMessage.addBodyPart(new MimeBodyPart(bodyPlain, "text/plain"));
composedMimeMessage.addBodyPart(new MimeBodyPart(body, "text/html"));
simpleMessageFormat == SimpleMessageFormat.HTML is HTML
composedMimeMessage.setSubType("alternative");
mimeType = multipart/mixed
String messageText = "<img src="data:image/png;base64,iVBORw0KGgoAAA.........AAALDGf//9D5EhiLEPUEK6AAAAAElFTkSuQmCC" alt="QR_IMAGE" width="100" height="100">"
textBodyBuilder = <img src="data:image/png;base64,iVBORw0KGgoAAAANSUhEUgAACAI..............EhiLEPUEK6AAAAAElFTkSuQmCC" alt="QR_IMAGE" width="100" height="100">
return textBodyBuilder.buildTextHtml(identity.getEmail(), receiverEmail);
simpleMessageFormat == SimpleMessageFormat.HTML is TEXT
messageContext = <img src="data:image/png;base64,iVBORw0KGgoAAAANSUhEUgAACAI..............EhiLEPUEK6AAAAAElFTkSuQmCC" alt="QR_IMAGE" width="100" height="100">
return textBodyBuilder.buildTextPlain(identity.getEmail(), receiverEmail);
queueMessageBuildSuccess(message);
message: MimeMessage@14096
mMessageId = <D8482783-50D6-4F86-85C3-405B19E0EE84@gmail.com>
MultiPartMime
b) In Gmail
Gmail seems to be completely dropping the image. By this I mean all I get in Gmail is the following ;
<img alt="QR_IMAGE" width="100" height="100">
The odd thing is this. If I manually insert the the image code src="data:image/png;base64,iVBORw
etc into the web browser via the developer console, the image then shows.
Thanks in advance.
