As far as I could see, the new version only allows searching in a specific folder, in the old version I could search in a specific folder or across all folders.
I could not find an option to do this again, does someone have a solution for this issue ? Thank you.
In the search results screen select “Search everywhere” in the menu.
Sorry, I haven’t noticed your answer earlier. Very Helpful ! Thank you very much. Best regards, Ulrich.
