How to restore an e-mail that has been accidentally deleted / moved to the wastepaper basket?
Thanks, Roland
Thanks, Roland
You should be able to simply move the mail from folder Trash to any other folder.
Clearly, I checked the … menu, but unfortunately, in my case (latest beta version), it doesn’t offer a “move” entry.
(I’m a very experienced user.)
It could also be that it is shown on the top bar if you have more space than me. I just checked when I use my phone in landscape mode. Then you have to look for a Folder symbol. By long pressing on the symbols you should get the command name.
