How to restore mails dropped to poubelle
Navigate to your trash folder and select all mails you want to restore. Then, move the mails to your inbox folder.
There is no “restore” functionality itself. You can only achieve the same effect by manually moving the deleted email.
If you have not set up a trash folder, you are in bad luck. K-9 then permanently deleted the mails as no target for moving is specified.
