[REQUEST] Subfolder organization
When clicking on the hamburger menu button, it shows the email being used. Then below it shows inbox, outbox, archive, drafts etc etc etc…
When you create a lot of folders to organize emails, K9 just displays the raw directory + sub directory as an endless list and if there are many directories and sub folders it becomes challenging to keep scrolling through to find a section.
It would be great if would display the root folders as collapsed then you can select a folder to expand it’s contents… I believe it would be called a tree directory?
If this could be added one day that would be amazing!!!
Something like this is badly needed.
