Problem with SMTP AUTH and GMX
since about two or there weeks I have had a strange problem with sending mails through my GMX Germany account.
I have setup 2FA with GMX and created an app password for K9. This is the same for IMAP and SMTP. Immediately after entering the password, sending works - until the next day or so. Then it complains it cannot login to the SMTP server.
I check the password - looks good. I clear the password and enter it again, then sending works again, until the next day again…
What’s wrong here? Is this a problem with GMX or with K9? I am or better was using K9 latest beta from the PlayStore beta Program, then switched to Thunderbird beta yesterday, which has the same problem.
Indeed they would have the same problem, because same code base.
Does your problem still exist? If it does can you submit your logs to the issue tracker?
