since K9 version 6.800 I can no longer add the PGB key with OpenKeycain version 6.0.4 with Android version 14.
I also added the K9 logs, and I have already done the standard things like emptying the cache and reinstalling without success Tried. Are there perhaps any possible solutions here?
Thanks LG
k9mail-logs
--------- beginning of system
03-10 19:41:56.713 4442 4442 E ActivityThread: Package [dk.tacit.android.foldersync.full] reported as REPLACED, but missing application info. Assuming REMOVED.
03-10 19:41:56.717 4442 4442 E ActivityThread: Package [dk.tacit.android.foldersync.full] reported as REPLACED, but missing application info. Assuming REMOVED.
--------- beginning of main
03-11 08:34:04.632 29063 29063 I com.fsck.k9: Using CollectorTypeCMC GC.
03-11 08:34:04.637 29063 29063 E com.fsck.k9: Not starting debugger since process cannot load the jdwp agent.
03-11 08:34:04.652 29063 29063 D CompatibilityChangeReporter: Compat change id reported: 171979766; UID 10352; state: ENABLED
03-11 08:34:04.652 29063 29063 D CompatibilityChangeReporter: Compat change id reported: 242716250; UID 10352; state: DISABLED
03-11 08:34:04.681 29063 29063 D nativeloader: Configuring clns-4 for other apk /data/app/~~whgEyLyLVyuIwHHnVrm2MQ==/com.fsck.k9-95xV_YMIREfqIVghsR_BKA==/base.apk. target_sdk_version=33, uses_libraries=, library_path=/data/app/~~whgEyLyLVyuIwHHnVrm2MQ==/com.fsck.k9-95xV_YMIREfqIVghsR_BKA==/lib/arm64, permitted_path=/data:/mnt/expand:/data/user/0/com.fsck.k9
03-11 08:34:04.687 29063 29063 V GraphicsEnvironment: Currently set values for:
03-11 08:34:04.687 29063 29063 V GraphicsEnvironment: angle_gl_driver_selection_pkgs=[com.android.angle, com.linecorp.b612.android, com.campmobile.snow, com.google.android.apps.tachyon]
03-11 08:34:04.687 29063 29063 V GraphicsEnvironment: angle_gl_driver_selection_values=[angle, native, native, native]
03-11 08:34:04.687 29063 29063 V GraphicsEnvironment: com.fsck.k9 is not listed in per-application setting
03-11 08:34:04.687 29063 29063 V GraphicsEnvironment: Neither updatable production driver nor prerelease driver is supported.
03-11 08:34:04.713 29063 29063 D CompatibilityChangeReporter: Compat change id reported: 279646685; UID 10352; state: DISABLED
03-11 08:34:04.735 29063 29063 W com.fsck.k9: Accessing hidden field Ljava/util/Collections$SynchronizedCollection;->mutex:Ljava/lang/Object; (max-target-o, reflection, denied)
03-11 08:34:04.735 29063 29063 W com.fsck.k9: Accessing hidden method Ljava/util/Collections$SynchronizedSet;->(Ljava/util/Set;Ljava/lang/Object;)V (max-target-o, reflection, denied)
03-11 08:34:04.735 29063 29063 W com.fsck.k9: Accessing hidden method Ljava/util/Collections$SynchronizedCollection;->(Ljava/util/Collection;Ljava/lang/Object;)V (max-target-o, reflection, denied)
03-11 08:34:04.736 29063 29063 D WM-PackageManagerHelper: Skipping component enablement for androidx.work.impl.background.systemjob.SystemJobService
03-11 08:34:04.736 29063 29063 D WM-Schedulers: Created SystemJobScheduler and enabled SystemJobService
03-11 08:34:04.741 29063 29063 D CompatibilityChangeReporter: Compat change id reported: 160794467; UID 10352; state: ENABLED
03-11 08:34:04.752 29063 29089 I DMABUFHEAPS: Using DMA-BUF heap named: vframe-secure
03-11 08:34:04.754 29063 29063 D AppCompatDelegate: Checking for metadata for AppLocalesMetadataHolderService : Service not found
03-11 08:34:04.775 29063 29063 D CompatibilityChangeReporter: Compat change id reported: 210923482; UID 10352; state: ENABLED
03-11 08:34:04.775 29063 29063 D CompatibilityChangeReporter: Compat change id reported: 63938206; UID 10352; state: DISABLED
03-11 08:34:04.805 29063 29063 I ContentCaptureHelper: Setting logging level to OFF
03-11 08:34:04.809 29063 29063 D CompatibilityChangeReporter: Compat change id reported: 237531167; UID 10352; state: DISABLED
03-11 08:34:04.909 29063 29063 W TextView: onProvideContentCaptureStructure(): calling assumeLayout()
03-11 08:34:04.910 29063 29063 W TextView: onProvideContentCaptureStructure(): calling assumeLayout()
03-11 08:34:04.917 29063 29063 D CompatibilityChangeReporter: Compat change id reported: 303326708; UID 10352; state: DISABLED
03-11 08:34:04.919 29063 29063 I ImeTracker: com.fsck.k9:ef376eb4: onRequestHide at ORIGIN_CLIENT_HIDE_SOFT_INPUT reason HIDE_SOFT_INPUT fromUser false
03-11 08:34:04.920 29063 29063 I ImeTracker: com.fsck.k9:ef376eb4: onFailed at PHASE_CLIENT_VIEW_SERVED
03-11 08:34:04.921 29063 29063 D AutofillManager: view not autofillable - not passing ime action check
03-11 08:34:05.953 29063 29063 I ImeTracker: com.fsck.k9:d7df5e5e: onRequestHide at ORIGIN_CLIENT_HIDE_SOFT_INPUT reason HIDE_SOFT_INPUT fromUser false
03-11 08:34:06.570 29063 29063 I ContentCaptureHelper: Setting logging level to OFF
03-11 08:34:07.163 29063 29063 D VRI[MessageList]: visibilityChanged oldVisibility=true newVisibility=false
03-11 08:34:07.621 29063 29063 I ContentCaptureHelper: Setting logging level to OFF
03-11 08:34:07.648 29063 29063 E com.fsck.k9: Invalid resource ID 0x00000000.
03-11 08:34:07.648 29063 29063 W TextView: onProvideContentCaptureStructure(): calling assumeLayout()
03-11 08:34:07.649 29063 29063 W TextView: onProvideContentCaptureStructure(): calling assumeLayout()
03-11 08:34:07.649 29063 29063 E com.fsck.k9: Invalid resource ID 0x00000000.
03-11 08:34:08.191 29063 29063 D VRI[SettingsActivity]: visibilityChanged oldVisibility=true newVisibility=false
03-11 08:34:08.209 29063 29089 D HWUI : endAllActiveAnimators on 0xb400006e4b517dc0 (FrameLayout) with handle 0xb400006f4b4d9ba0
03-11 08:34:08.583 29063 29063 W WindowOnBackDispatcher: OnBackInvokedCallback is not enabled for the application.
03-11 08:34:08.583 29063 29063 W WindowOnBackDispatcher: Set 'android:enableOnBackInvokedCallback="true"' in the application manifest.
03-11 08:34:08.639 29063 29063 E com.fsck.k9: Invalid resource ID 0x00000000.
03-11 08:34:09.351 29063 29085 I K9StorageEditor: Committing preference changes
03-11 08:34:09.362 29063 29085 I K9StorageEditor: Preferences commit took 10 ms
03-11 08:34:09.653 29063 29085 I K9StorageEditor: Committing preference changes
03-11 08:34:09.661 29063 29085 I K9StorageEditor: Preferences commit took 8 ms
03-11 08:34:10.104 29063 29131 D ProfileInstaller: Installing profile for com.fsck.k9
03-11 08:34:10.248 29063 29063 E com.fsck.k9: Invalid resource ID 0x00000000.
03-11 08:34:10.249 29063 29063 E com.fsck.k9: Invalid resource ID 0x00000000.
03-11 08:34:11.928 29063 29063 D VRI[GeneralSettingsActivity]: visibilityChanged oldVisibility=true newVisibility=false
03-11 08:34:11.944 29063 29063 W WindowOnBackDispatcher: sendCancelIfRunning: isInProgress=falsecallback=android.view.ViewRootImpl$$ExternalSyntheticLambda11@7a1d9f5
03-11 08:34:11.945 29063 29089 D HWUI : endAllActiveAnimators on 0xb400006e4b55bdb0 (RippleDrawable) with handle 0xb400006f4b4f8da0
03-11 08:34:12.223 29063 29063 I ContentCaptureHelper: Setting logging level to OFF
03-11 08:34:12.240 29063 29063 W WindowOnBackDispatcher: OnBackInvokedCallback is not enabled for the application.
03-11 08:34:12.240 29063 29063 W WindowOnBackDispatcher: Set 'android:enableOnBackInvokedCallback="true"' in the application manifest.
03-11 08:34:12.283 29063 29063 E com.fsck.k9: Invalid resource ID 0x00000000.
03-11 08:34:12.284 29063 29063 E com.fsck.k9: Invalid resource ID 0x00000000.
03-11 08:34:12.751 29063 29063 D VRI[SettingsActivity]: visibilityChanged oldVisibility=true newVisibility=false
03-11 08:34:12.764 29063 29089 D HWUI : endAllActiveAnimators on 0xb400006e4b525f10 (DraggableFrameLayout) with handle 0xb400006f4b4fcdc0
03-11 08:34:12.870 29063 29063 W WindowOnBackDispatcher: OnBackInvokedCallback is not enabled for the application.
03-11 08:34:12.870 29063 29063 W WindowOnBackDispatcher: Set 'android:enableOnBackInvokedCallback="true"' in the application manifest.
03-11 08:34:12.942 29063 29063 E com.fsck.k9: Invalid resource ID 0x00000000.
03-11 08:34:12.943 29063 29063 E com.fsck.k9: Invalid resource ID 0x00000000.
03-11 08:34:14.424 29063 29135 I K9StorageEditor: Committing preference changes
03-11 08:34:14.425 29063 29063 D OpenPgpApiManager: callback provider status changed from UNCONFIGURED to UNINITIALIZED
03-11 08:34:14.425 29063 29063 D OpenPgpApiManager: attempting to bind to openpgp provider: org.sufficientlysecure.keychain (org.openintents.openpgp.util.OpenPgpServiceConnection@4d03366)
03-11 08:34:14.432 29063 29135 I K9StorageEditor: Preferences commit took 7 ms
03-11 08:34:14.432 29063 29102 V PushController: PushController.updatePushers()
03-11 08:34:14.432 29063 29102 V PushController: ..Running PushControllers: [e038a253-b520-4d6e-847a-8aa6373bfed0, 8f5b19a6-340e-4b27-8a02-8952ae9cda0a]
03-11 08:34:14.434 29063 29114 V AccountPushController: AccountPushController(8f5b19a6-340e-4b27-8a02-8952ae9cda0a).updatePushFolders(): [INBOX]
03-11 08:34:14.434 29063 29114 V ImapBackendPusher: ImapBackendPusher.updateFolders(): [INBOX]
03-11 08:34:14.434 29063 29111 V AccountPushController: AccountPushController(e038a253-b520-4d6e-847a-8aa6373bfed0).updatePushFolders(): [INBOX]
03-11 08:34:14.434 29063 29114 V ImapBackendPusher: ..limiting Push to 0 folders: []
03-11 08:34:14.435 29063 29111 V ImapBackendPusher: ImapBackendPusher.updateFolders(): [INBOX]
03-11 08:34:14.435 29063 29111 V ImapBackendPusher: ..limiting Push to 0 folders: []
03-11 08:34:14.437 29063 29102 V PushServiceManager: PushServiceManager.start()
03-11 08:34:14.437 29063 29102 V PushServiceManager: ..PushService already running
03-11 08:34:14.437 29063 29102 V BootCompleteManager: Enable BootCompleteReceiver
03-11 08:34:14.604 29063 29063 D OpenPgpApiManager: callback provider status changed from UNINITIALIZED to UI_REQUIRED
03-11 08:34:15.041 29063 29072 W com.fsck.k9: Cleared Reference was only reachable from finalizer (only reported once)
03-11 08:34:15.074 29063 29074 W com.fsck.k9: ApkAssets: Deleting an ApkAssets object ' and /data/app/~~n8cDvfHid-6_etBNOxxQjA==/org.sufficientlysecure.keychain-UQB45eYQN_0KLlOYlv9SJw==/base.apk' with 1 weak references
03-11 08:34:15.074 29063 29074 W com.fsck.k9: ApkAssets: Deleting an ApkAssets object ' and /data/app/~~n8cDvfHid-6_etBNOxxQjA==/org.sufficientlysecure.keychain-UQB45eYQN_0KLlOYlv9SJw==/split_config.de.apk' with 1 weak references
03-11 08:34:15.075 29063 29074 W com.fsck.k9: ApkAssets: Deleting an ApkAssets object ' and /data/app/~~n8cDvfHid-6_etBNOxxQjA==/org.sufficientlysecure.keychain-UQB45eYQN_0KLlOYlv9SJw==/split_config.xxhdpi.apk' with 1 weak references
03-11 08:34:17.475 29063 29063 D VRI[AccountSettingsActivity]: visibilityChanged oldVisibility=true newVisibility=false
03-11 08:34:17.494 29063 29063 W WindowOnBackDispatcher: sendCancelIfRunning: isInProgress=falsecallback=android.view.ViewRootImpl$$ExternalSyntheticLambda11@45dd2ee
03-11 08:34:19.855 29063 29087 I MessagingController: Running command 'clearNotifications', seq = 2 (foreground priority)
03-11 08:34:19.855 29063 29087 V NotificationController: Removing some notifications for account e038a253-b520-4d6e-847a-8aa6373bfed0
03-11 08:34:19.855 29063 29087 I MessagingController: Command 'clearNotifications' completed
03-11 08:34:20.390 29063 29063 D VRI[SettingsActivity]: visibilityChanged oldVisibility=true newVisibility=false
03-11 08:34:20.403 29063 29089 D HWUI : endAllActiveAnimators on 0xb400006e4b532d10 (RippleDrawable) with handle 0xb400006f4b4fd840
03-11 08:34:20.414 29063 29063 W WindowOnBackDispatcher: sendCancelIfRunning: isInProgress=falsecallback=android.view.ViewRootImpl$$ExternalSyntheticLambda11@9437ebb
03-11 08:34:21.347 29063 29063 I ImeTracker: com.fsck.k9:17018c43: onRequestHide at ORIGIN_CLIENT_HIDE_SOFT_INPUT reason HIDE_SOFT_INPUT fromUser false
03-11 08:34:21.704 29063 29063 I ContentCaptureHelper: Setting logging level to OFF
03-11 08:34:22.246 29063 29063 D VRI[MessageList]: visibilityChanged oldVisibility=true newVisibility=false
03-11 08:34:22.380 29063 29063 I ContentCaptureHelper: Setting logging level to OFF
03-11 08:34:22.412 29063 29063 E com.fsck.k9: Invalid resource ID 0x00000000.
03-11 08:34:22.413 29063 29063 W TextView: onProvideContentCaptureStructure(): calling assumeLayout()
03-11 08:34:22.413 29063 29063 E com.fsck.k9: Invalid resource ID 0x00000000.
03-11 08:34:22.414 29063 29063 W TextView: onProvideContentCaptureStructure(): calling assumeLayout()
03-11 08:34:22.948 29063 29063 D VRI[SettingsActivity]: visibilityChanged oldVisibility=true newVisibility=false
03-11 08:34:22.956 29063 29089 D HWUI : endAllActiveAnimators on 0xb400006e4b54e940 (FrameLayout) with handle 0xb400006f4b4fc790
03-11 08:34:23.396 29063 29063 W WindowOnBackDispatcher: OnBackInvokedCallback is not enabled for the application.
03-11 08:34:23.396 29063 29063 W WindowOnBackDispatcher: Set 'android:enableOnBackInvokedCallback="true"' in the application manifest.
03-11 08:34:23.445 29063 29063 E com.fsck.k9: Invalid resource ID 0x00000000.
03-11 08:34:25.060 29063 29063 D CompatibilityChangeReporter: Compat change id reported: 171228096; UID 10352; state: ENABLED
03-11 08:34:25.095 29063 29063 W TextView: onProvideContentCaptureStructure(): calling assumeLayout()
03-11 08:34:26.324 29063 29063 W WindowOnBackDispatcher: sendCancelIfRunning: isInProgress=falsecallback=android.view.ViewRootImpl$$ExternalSyntheticLambda11@9290caf
03-11 08:34:26.326 29063 29089 D HWUI : endAllActiveAnimators on 0xb400006e4b5bda00 (MenuPopupWindow$MenuDropDownListView) with handle 0xb400006f4b508b20
03-11 08:34:26.698 29063 29063 D VRI[GeneralSettingsActivity]: visibilityChanged oldVisibility=true newVisibility=false
03-11 08:34:27.342 29063 29063 D CompatibilityChangeReporter: Compat change id reported: 78294732; UID 10352; state: ENABLED
03-11 08:34:27.343 29063 29063 W WindowOnBackDispatcher: OnBackInvokedCallback is not enabled for the application.
03-11 08:34:27.343 29063 29063 W WindowOnBackDispatcher: Set 'android:enableOnBackInvokedCallback="true"' in the application manifest.
03-11 08:34:27.368 29063 29063 E com.fsck.k9: Invalid resource ID 0x00000000.
I solved the problem by deleting the data on OpenKeycain and resetting the key…
lg
