Can someone help me, please with the (Imap) settings to use an “@live.de” (german) E-Mail adress at K9?
Anything i have googled didnt work.
Thank you
Thank you
Try searching:
live.de imap settings
in your search engine of choice. That should bring up an array of resources. Looking at a few they all had the same information.
By the way, as this is a MS Outlook account and they seem to be requiring OAuth you may need to set up an “app password” in MS as K9 doesn’t support OAuth. You can try your regular login credentials, but if they fail look up their way of creating an app password.
