I’m running K-9 v. 6.301 on Android v. 6.0.1 on a Samsung Tablet SM-T700. Some emails are sometimes placed by K-9 in the Outbox even when the tablet is connected to wifi, and then they are not sent by K-9 despite me pressing Send (from within Outbox) and despite me repeatedly refreshing (from within Outbox or from the Unified screen).
But normally sending works fine, only somtimes the mails are stuck in Outbox folder?
You are using a Beta version, ie 6.301. Did that happen on previous versions as well? Is there sometging specific to these messages, e.g big attachments.
As this problem is discovered long after K-9’s occasional failure to send an email, would sending a debug log of the failure be possible? If so, please tell me how to do it.
If after sending an email I have to to always go and check my outbox to ensure that it has actually been sent, I might as well abandon K-9 and use one of my two other email apps which never put things in the Outbox.
First go to Settings / General Setings / Debugging / Enable debug logging
When you encountered that issue go to
Settings / General Setings / Debugging again. In the 3dot menu you see “Export logs”
I do not know how long back the logs are kept but I assume that you should check at least once a day if that behavior occurs.
I understand this. But without debug log files the devs might not have a chance to fix this issue if it is a bug in K9. So maybe try for a certain time.
