If I answer a mail the header part of the created message only shows"+1" in the “to” field not the address as it would be in a normal message (no answer) I think this must be a bug not a feature.
Dimitri
Dimitri
That happens if the address is long. If you press on the To:/Cc: line the full address should show. There’s no problem with the address and the message send correctly.
