Using Version 6.904 com.fsck.k9 also tried google play store 6.804 and aurora version.
K-9 Mail wants to access your Google Account takes to google search page
And oath failed when setting up gmail account. It happened after setting up second of gmail accounts. Also first account now also fails and reinstall also fails
Have used older versions 5.714 same result requesting google approval I the K-9 link takes me to google search page
Dear EMS_Saab99
I’m a little confused by the explanation you posted, so I’ll take a guess.
Let me assume that you are already logged in to the Google account you want to add in your smartphone.
Add account
Enter your email address
K9 mail finds your account
Tap “Login with Google
In the in-app browser, the account you are logged in to is displayed and you tap it.
Tap “Allow” on the page where K-9mail makes a request to your Google account.
Your account will be registered.
In the order of adding an account in K-9mail, is there an authentication failure at “The account you are logged in to in the in-app browser is displayed and you tap it”?
If you can explain this area, we will be able to better support you.
