No sent folder available
No “sent” folder is available
Hi, Welcome to the forum.
Q) Are you using an Imap or pop connection to the server?
Check you have a folder name assigned to the “sent folder”.
  1. Navigate to settings > account name > folders
  2. Sent folder will typically be set as “automatic(sent)”. Assign a folder if “none” is set.
You may also try refreshing the folder list.
  1. Open the side menu to show your account folders.
  2. Tap manage folders (bottom of list).
  3. Tap three dot menu > refresh folder list.
Same problem. Only folder in account is “automatic” with “Inbox”, nothing else there. In both email accounts, both pop3.
There is no “manage folders” in the side menu. Only “inbox” is in the side menu.
Version 21.1
I guess I have only one folder in the account because it’s pop3.
Still confusing: the folders in the side menu only appear when I select one account.
