Often I do have this problem, all settings are ok, IMAP and all, uploaded just fine all emails. But whenever I want to go to Inbox I see there are zero of my around 100 folders. They never show up.
→ Yes, I did activate all active sync folder
→ Yes, push folder
→ Yes, activation on my internal webmail to activate synchronization (external)
→ Yes, I have waited for a few hours
→ Yes, O restarted the phone and app multiple times
I really don’t understand why the folders are not showing up, any help would be so amazing :)!
Have you set to display all folders? By default, the folders’ class is “none,” and if you only display 1st and 2nd class, you won’t see the “none” once.
Yes thanks @tchara it just shows either NONE or 1st CLASS or 2nd CLASS whatever those classes are. They should be called ALL FOLDERS but they’re not :).
“Same as push class”, “same as display class”, no class, 1st class. So I have them all on first class as they were standard. Confusing.
There is NO “All Folders” to be found in my latest K9 app when managing folders.
Oh yes @tchara I also have them in the one setting as “all folders” and now I placed them all from 1st to “none” then refreshed. Hope they will start appearing, my folders.
