Move to folder beneath android navigation buttons
I have installed and used android version 13.0 for this problem.
When I open an email or select it via message list I can choose “move to” folder via 3 dot menu and get a list of my imap folders, but when a folder is at the end of the list (in my case the trash folder, but it could also be another folder) then this folder is “behind” the navigationbuttons of android. And I can’t hide this android system buttons. I blurred my private details for the screenshot.
I have a Samsung S20 FE with android 13.
Regards Sebastian
Hello @Hustensirup
I have Samsung Galaxy S24FE, Android 16, Thunderbird 13.0.
For me it looks as expected.
In your case Sent Foldet is behind the Navigation Buttons, it doesn’t seem to be the last folder? Or you have less folders (I have made the screenshot while scrolling to show the scrollbar because I have more than 20 folders)?
“Sent” is the last for me. I have a lot of folders. No overlap with the Navigation bar for me.
@Hustensirup This issue you report is fixed and scheduled for inclusion in version 14’s release
ha, same issue is under identities, i hope it was fixed in one go
Hi @ketas
I don’t think anyone has previously reported an issue with identities conflicting with the navigation buttons. Do you have a screen shot of the issue?
If you experience the issue on v14, please create a bug report on Github so the developers can investigate and fix.
did add bug. no screenshot because that blows the antispam system
that is also reason why it has so many.
and i wish there’s better management of such kind of lists
