When I send a message from K-9 on my Samsung A14, it ends up in the “Sent” folder but never reaches the recipient. No error message appears. I believe my outgoing server settings are correct.
If it matters, my incoming mail uses IMAP and I’m using SSL/TLS for outgoing.
Has anyone else seen this? And is there a log somewhere that might give me more information?
Thanks.
What mail provider do you use? It is known that Hostgator does show exact that behavior you describe. (Search for hostgator on this forum)
If that is the case: currently no solution as hostgator says K-9 has to change its behavior. And K-9 says the same about hostgator.
Yup. Hostgator. Thanks. I’ll do a search.
