Location of downloaded attachments / files is not Downloads folder?
in more recent versions of K9-Mail, there is no more option in the settings to select the Download folder (but K9 used to have that, IIRC. Is it gone or is this a bug?).
When I press the Download button next to an attached file, the file does not end up being saved in the “Downloads” folder of the device (neither internal storage nor external SD card Downloads). Where does K9-Mail save attachments to nowadays?
Additional question: When I have a calendar invitation (ics file) and do not download it by the download button, but click on it directly, my calendar app (business calendar) opens up for importing, but it cannot find the file at the preset location. Where is the file temporarily stored in this other use case? (is it a limitation of K9, or more likely business calendar or Android in general that I cannot hand over the file from K9 to calendar?)
kind regards
When you press the download button on an attachment, you’ll be prompted for a storage location. The file will be saved in whatever location you select.
Not being able to display an ICS attachment directly opened from K-9 Mail is a bug in Business Calendar. Other calendar apps handle this just fine.
This seems to have changed in version 8.2: in the save dialogue, it seems that only the file name can be changed directly.
One has to open the hamburger menu (top left) to choose a folder.
This seems to be another user un-friendly change.
That’s the Android system file picker. K-9 has no influence on its user interface. On recent Android versions, it has to use the Android system one because of changes in Android’s storage access permissions.
