It is suggested to add language translation function similar to Gmail
My English level is not very good, so I am often troubled by this aspect. I suggest that the author can consider adding the mail language translation function, which can be added in the form of plug-ins or other forms, so that people who need it and those who do not need it can choose independently. I think it is good to refer to Gmail mailbox.
Mr. Esamny_Seanmy
The easiest way to change the language now is to select [Select All] - [Share] - [Google Translate] - [Copy Translated Text] - [Select All Email Texts] - [Paste] when you are done writing the body of the email.
It is convenient and very easy to return to the email composition codification, so please try it.
