Irritating notification sound when fetching mail
In the new version, when receiving mail, there is an irritating notification sound for each email downloaded. Is there anyway to turn it off? If so, I can’t find it.
I got that too initially. Go into your Settings, then General Settings, and Notifications. You should be able to turn them off from there, (if I remember correctly.) If that’s not it, just search your settings and you will find it.
Dear Jackie,
Thank you for your suggestion. In the end I went into Android settings, notifications. I saw K9-mail there and found 2 message notifications both of which I set to silent. I think that has fixed it.
Good to hear. When it first happened I wondered what was happening to my phone then realised it was the new update on K9. Glad you got it sorted.
