Increase font of email body
I noticed that when reading my emails, the font size has decreased. I went to settings - General - Display and I no longer see a slider bar for increase size. I went my android settings and increased font, but the email body has not increased. I am currently running vs 14. Is there a way to increase the font of the email body so it can be read easily?
The slider is still there in version 14.0 but it’s hidden.
You can access it In global settings by searching for font size. However, whatever you set the font size to it does not persist. When the app is closed and then reopened the font size reverts to the default of 100.
I believe version 12.1 is the last version where the slider was accessible directly.
Until some means of font sizing e.g. through system settings, the only solution is to install version 12.1 making sure it’s not set to auto update. The apk for version 12.1 is available to download from several reliable sites.
>”You can access it In global settings by searching for font size. However, whatever you set the font size to it does not persist. When the app is closed and then reopened the font size reverts to the default of 100.”
That’s exactly, how it is. I can hardly read my mails an longer.
This change is quite exhausting.
Why modify something, that was working perfectly fine?
Please change it back!
I thought I was going nuts, relieved to find others are having the same problem.
I hope the devs read this forum, I thought bugs like this were supposed to be ironed out in Thunderbird beta.
