When I try to load mails from GMX and WEB.DE accounts IMAP and POP3, they are empty on my Samsung Galaxy S21FE.
Are you using IMAP or POP3? And if you pull down in the inbox: Does that change something?
Hi, both, IMAP and POP3-Accounts are affected. Pulling down the inbox loads new mails, when I open them, they are empty.
Did you try to restart your phone after this happened?
Ignore the part about bluetooth but restart seems to solve what you see.
Hi stphn,
thank you so much, restart solved the problem.
