First I think that there are two issues here.
- Export and Import failed to set up New phone correctly!!
- “Network error - Unable to parse TLS packet header”
I copy the text of my mail to Startmail Support
I’ve now run into a problem migrating to a new phone.
Old Phone - Samsung S20+ - using K9 Mail
New Phone - Google Pixel 8a - using K9 Mail
I didn’t want to migrate everything, so I set up most things fresh. however I uploaded a settings export from K9 Mail, to a cloud acount.
On downloading this settings file to the Pixel phone I was getting “failure to authenticate” repeatedly. (reason given below)
I deleted K9 Mail and re-installed it, and used the exported settings again. Same result.
This time I checked the settings manually and found/remembered that Startmail use a different password for Browser and for Apps like Thunderbird and K9 Mail.
I changed the password on the Receive Setting and now I’m getting my mail, however for the Send Setting it gives a different error,
“Network Error Unable to Parse TLS Packet Header”. Upon the failure to connect, the password reverts every time to the incorrect one.
I don’t know why K9 Mail’s Settings Export didn’t export the FULLY WORKING SETTINGS correctly from my Samsung! That may be K9 Mail’s issue, and I will contact them as well!!
But can you help me to understand, and correct, why I am unable to get the settings changed correctly and to work - as they do on my old Samsung.
I am pasting the correct password direct from my password manager, so I don’t think that there CAN be an error there…
Other than the password issue, I can find no other setting that is different on the two phones…
As a user of a VPN, I also tried pausing Nord VPN for one of my attempts to get it working - no joy…
I also shut down the old Samsung for one attempt, just in case having two Phones with K9 Mail, connecting with Startmail was an issue, this didn’t work either…
I sure hope that you (Startmail) and or K9 Mail can help me!
