IMAP sync only works for Inbox and Trash
Hi there,
this is driving me crazy and it’s getting worse. :pleading_face:
For a long time all folders but Inbox and Trash did only sync when I entered them and pulled down to do a manual reload (I had no the energy to look into this, as I still was able to get the nails(
Since the update to 12.1 (could be that I skipped 12.0) it does not work at all anymore.
Example:
  1. I start typing a mail in Thunderbird on my computer and save it in drafts
  2. I found no way to get this mail in K9
  3. Same with sent mails
  4. It also does not work the other way around (mails from the sent and drafts folder in K9 don’t show up anywhere else)
  5. The Mails are definitely on the server as I can see them via webmail there
  6. The mailbox is a generic IMAP at df.eu
What have I tried:
  1. I checked folder names for a German/English problem (there is just one folder “sent in the account, nothing like “gesendet” in the refreshed folder list).
  2. Strangely there a two folders with “Drafts” in the name. One is only “Drafts” and the other is “INBOX.Drafts” - but this is also the case for the Trash folder where everything works fine and this could not explain the problem with the sent (and archives) folder.
  3. Drafts and INBOX.Drafts as well as Trash and INBOX.Trash instantly have the same content in Thunderbird, as if they are symbolic links on the server.
  4. In K9 the INBOX.Drafts and INBOX.Trash are empty and won’t load anything on a refresh
  5. In K9 Drafts does not sync with the server (despite it’s active in the folder settings) and Trash works just fine.
  6. I checked that the upload for sent mails is activated
  7. I enabled sync for every folder found in the refreshed folder list but couldn’t find the mail saved in Thunderbird in any of them
  8. I enabled everything available under folder settings, except notifications and integration to joint inbox (I don’t use that)
  9. Sync timeframe is indefinitely and limit is set to 1000 messages
  10. “Load next 1000 messages” does nothing
  11. I even recreated the mail account in K9
I know this screams: “This is a folder naming issue” and it’s seems there could be no other reason, but I looked into that in my tries #1, #2 and with no result.
Just as an overview here the stucture and behaviour in both apps:
Summary K9
  • INBOX (syncs fine)
  • INBOX.Drafts (is empty and does not sync)
  • INBOX.Trash (is empty and does not sync)
  • Drafts (stores local drafts but does not sync)
  • Sent (stores local sent mails but does not sync despite upload and sync are active in settings)
  • Trash (syncs fine)
Summary Thunderbird
  • INBOX (syncs with webmail)
  • INBOX.Drafts (instantly same content as Drafts)
  • INBOX.Trash (instantly same content as Trash)
  • Drafts (syncs with webmail)
  • Sent (syncs with webmail)
  • Trash (syncs with webmail)
INBOX.Drafts and INBOX.Trash are not deletable.
I have no ideas left what I can look into… :person_shrugging:
Looking curiously forward to your suggestions,
Thomas
Ps: I don’t know if this is related: the “search on server” does also not work (I would rather open another topic for that to keep things clean and separate)
Hi @Thomas_H.
I am told that “Accounts that enforce IMAP prefixes are bugged on 12.x and will cause that issue. If the user is using the Beta version from the Play Store or has downloaded TfA from F-Droid, they will have this issue. To workaround this issue, the user can go to Settings > Account Settings > Fetching mail > Incoming server, disable the “Auto-detect IMAP namespace” and leave the IMAP path prefix empty.”
Also reported in Klasör mail yukleme | Thunderbird Destek Forumu | Mozilla Destek
Does that help??
The pb est corrected for me, version 12.1
Thx you.
This topic was automatically closed 180 days after the last reply. New replies are no longer allowed.
