IMAP Push Not Working on v22 on Android 17
New Pixel 11 Pro, migrating from K-9 Mail v. 6.603 on Pixel 8 where everything worked fine. Used Google Setup, which transferred everthing from Pixel 8 to Pixel 11 Pro. Everything seems to have transferred fine, including multiple identities on all accounts. Entered K-9 Mail passwords for all email accounts when prompted during the transfer. Sending works, manually checking mail works, but no push. Double-, triple-, and quadruple-checked (and more) incoming server settings, and Push is indeed enabled on Inbox.
Tested many, many times, and v22 on Pixel 11 never gets push, yet Pixel 8 push works every time. This version has no option to see Folder Classes, so I am stuck there.
I’ve been using K-9 Mail for years, so this is very frustrating. Is there a bug here? Can I revert back to v6.603 on the Pixel 11 Pro somehow?
Thank you.
It suddenly started working. Although I previously tried it before my making my initial post, it may have been solved by changing Optimization to Unrestricted under Settings/Apps/K-9 Mail/App battery usage/Allow background usage, then waiting a while for the change to take effect.
Same with my new Google Pixel 10a.
Hi @Radelt
Have you enabled the Push service on desired folders as shown in this guide?
Do you see the Push service notification in Androids notification drawer?
I use K9 mail on Pixel 4a, Pixel 8a and Pixel 10a, all the K9 settings I store and load in a new K9 installation.
Pixel 4a and Pixel 8a work fine, I get new mail immediately, Pixel 10a no, only manual with the same settings.
Push is on.
Gruß Wolfgang
Google Pixel 11 Pro, same problem. Push isn’t working. On my Google Pixel 9 Pro all was good. Hope to find a fix for this problem.
I have try all guides, Push is on no battery saving …
Battery Saving setting has nothing to do with it, so it seems. See my last post above. That should take care of the issue.
