How to set Spam and the way to save emails
Hi, there.
How can I save some emails, for a later review.
Also a want to know the way to set a email as Spam?
Thank you.
J C. León.
The control of message display in your K9 inbox depends on your account type (imap/pop) and your “settings/[account/]fetching mail” settings.
If pop, the messages will stay there until you delete them.
With imap, the “sync server deletions” setting will impact whether a message is removed from the K9 inbox display when it is moved/deleted from the server’s mailbox by another client or process. If that box is checked, the client and server inboxes will be kept in sync.
For spam … if you have a spam folder configured “settings/[account/]folders” then you can move a message to that (server-side) folder. What happens to it on the server side is a server issue. In some environments messages in that folder are used to inform subsequent message handling. In others it’s just a repository of mail you don’t want to read.
Thank you. Have a nice day.!
