I used K-9 years ago and have returned to it. So far, so good but I have one question. If this is a FAQ or known question, please point me in the right direction. I searched, but found nothing revealing.
I want to push my inbox and a few select folders, but poll the rest less frequently. I understand how to do this with folder classes. My folders are apparently set by default to 1st Class but somehow the concept of the more “important” folders being a lower class than 1st seems backward. So I’d like to set them all to None then set only the appropriate ones to 1st, 2nd, whatever.
However, I can’t find a way to bulk-set the folder classes, i.e., do them all at once. I have a lot of folders over multiple accounts. Do I have to go through each and every one, manually setting it to None?
Also, when new ones are added, will they default to 1st or can I set the new folder default class?
Thanks!
[ Edit ] – Oops, forgot to mention I’m running 6.602 on Android 13, Google Pixel 4a
