How to downgrade to an earlier version?
Android does not support downgrading an app. So you have to uninstall the app, then install the old versions you want to continue using. Before doing that, you probably want to export your settings, though.
Export K-9 Mail settings
  1. Open the drawer
  2. Select Settings
  3. Select Export settings
  4. Tap the Export button
  5. Select a destination and tap the Save button
Disable auto update in Google Play
  1. Open the Play Store app
  2. Go to the details page of K-9 Mail
  3. Open the “three dots” menu in the upper right
  4. Uncheck Enable auto update
Uninstall the app
Uninstall the app like you normally do.
Download an old version of K-9 Mail
  1. Go to the Releases page on GitHub and select the version you want to downgrade to (e.g. K-9 Mail 5.600 is the last version with the old design)
  2. Download the APK file listed under Assets (e.g. k9-5.600.apk)
Install the old version
Install the APK you just downloaded. You might have to change some Android settings to allow installing side-loaded apps.
Import settings
  1. Start K-9 Mail
  2. Tap the Import settings button in the lower left corner
  3. Select the settings file you created in the Export K-9 Mail settings step
  4. Confirm the selection
  5. Enter account passwords
K-9 Mail 5.600+ allow importing settings created with newer versions of the app, but some settings might be ignored (because their internal name and/or data format has changed).
Done
Please note that we’re not interested in getting bug reports for old app versions. If you decide to use an outdated version you’ll have to live with all of its bugs.
However, feel free to use this forum to ask for help. But please make sure to mention the version you’re using, ideally in the title, e.g. [5.600] Can’t find setting to disable the Unified Inbox.
Option to switch back to the old UI?
Ver 5.8 update, made k9mail useless
K-9 5.800 List of email accounts after startup
K-9 Mail is back (5.800 release)
Old presentation
How to downgrade to the "good" version (before this silly UI update)?
Where is the opening list of accounts?
Accounts overview screen
Any chance to fork the old version as a new (paid) app?
How to get version 5.6
I'm really pissed off
Old version apk
V6.6 color change
Possible to previous version of K9 Mail?
Please share the last APK with 1minute poll frequency
I'm rather angry!
Not Sending Emails from Cellphone
Account Overview. Please get it back or enable it by a feature toggle
Trouble logging in to my freemail.hu account
How to safely downgrade without losing the settings?
Display customization
UI Upgrade including toolbar rearrange breaks onehand usage
Un update possible?
Download older version?
5.8 How do I move the navigation buttons back down to the bottom of the screen where they should be?
Probably worth adding this from another thread?
In case you want to use the F-Droid version: They have now removed the old apk from their main repo, so you need to use the archive repo to get it: https://f-droid.org/archive/com.fsck.k9_26000.apk
