I have K9 set up with 3 separate email addresses but when I sync I only want it to check 2. The third one I want to keep on the phone but I want to kind of disable it temporarily. I don’t want to remove it completely because I plan on using it again later and I don’t want to have to set it all up again.
So is there a way to set it so that when I check my mail it does not check that account?
